fitted system boiler vaillant 24kw
colin h bell
by colin h bell » Mon Aug 11, 2008 8:48 pm
contracter fitted system boiler in my property vaillant ecotech 24 kw i switch on the programer to give me hot water 1hour before i get up in the morning there is on ly enough hot water for one shower and the water is not that hot can any one help me with this problem .the only time i get hot water is if i have my central heating on could the problem be my pump please help colin
by htg engineer » Tue Aug 12, 2008 9:24 pm
Definately a Vaillant Ecotec 24 ???? this is a combi boiler
The Vaillant Ecotec system boilers are
Vaillant Ecotec Plus
612 - 12kw
615 - 15kw
618 - 18kw
624 - 24kw ?????? possibly yours ?
630 - 30kw
637 - 37kw
Please confirm the boiler you have.
htg
colin h bell
boiler
by colin h bell » Tue Aug 12, 2008 9:28 pm
sorry it is a 624 colin
colin h bell
Re: fitted system boiler vaillant 24kw
by colin h bell » Tue Aug 12, 2008 9:29 pm
[quote="colin h bell"]contracter fitted system boiler in my property vaillant ecotech 24 kw i switch on the programer to give me hot water 1hour before i get up in the morning there is on ly enough hot water for one shower and the water is not that hot can any one help me with this problem .the only time i get hot water is if i have my central heating on could the problem be my pump please help colin[/quote] sorry it is a 624 system boiler
by htg engineer » Tue Aug 12, 2008 9:33 pm
Sorry mis-read your post I thought it said Vaillant Ecotec 24, but it says 24kw.
What is the HW thermostat set to ? does turning the thermostat up solve the problem ?
If no luck, get the installer back to check the gas pressures. As the water is getting hot, but not hot enough it may be the gas pressures are not set correctly therefore unable to heat the water effectively.
htg
It is currently Fri Jan 10, 2025 4:11 pm
