lighting circuit
carl123uk
lighting circuit
by carl123uk » Wed Aug 13, 2008 6:49 pm
im wiring up 2 flurorescent lights on a new circuit that needs to be operated by two seperate switches about 15ft away. can somebody give me a wiring diagram from consumer unit to the lights and switches?
thanks
TheDoctor4
by TheDoctor4 » Thu Aug 14, 2008 9:14 am
Have you had a look at the DIY Projects section of the site. There are quite a few projects relating to Electrics that may be of some help: https://www.diydoctor.org.uk/projects.htm
by ericmark » Thu Aug 14, 2008 4:03 pm
I really wonder if you need a wiring diagram should you be doing the job? Also if coming from the consumer unit it would be part P. But in true Blue Peter style here is one I did earlier http://www.ericmark.talktalk.net/twoway.html if you scroll to bottom there are some diagrams.
Remember being an electrician is 20% getting things to work and 80% knowing all the rules and regulations so do be careful.
Eric
It is currently Wed Jan 29, 2025 9:34 pm
