hot water
neilbradshaw
hot water
by neilbradshaw » Sun Aug 17, 2008 3:05 pm
use about 7 ltrs of water before water starts to run hot. this problem applies to all rooms in the house. any suggestions?
BoyElectric
by BoyElectric » Wed Aug 20, 2008 9:37 pm
2 suggestions:
1. Post more info about your system type, etc - A reasonably sized house on a vented cylinder with poorly insulated pipes could easily contain 7 litres of cold water in the pipes which has to be drawn off before you get hot water.
2. Save the cold water for watering the garden.
by htg engineer » Thu Aug 21, 2008 3:56 pm
Type of boiler/system ?
How much pipework between boiler/tank and taps ?
7ltrs isn't that much - it'll just be what is sitting in the pipes, obviously it will cool the longer it sits there without the taps being opened. This cold water will have to come through before the hot from the tank/boiler gets to the taps.
Turn off the hot water supply, then open a tap. I bet you get more or less 7ltrs of water just from the pipework.
Hospitals and schools hot water supplies are in a continuous pumped loop, exactly for that reason, the difference being the size of the building, maybe having to run 70 ltrs before getting any hot water - would cause problems.
Reduce pipe run lengths if possible and insulate pipework.
htg
It is currently Sat Nov 23, 2024 4:02 am
