Hi Again,
I have a problem with the cold water feed to my bathroom, the gate valve used to isolate water being fed from the CWST in the loft is closed and just spins when turned. A local plumber has recommended that the full system needs to be drained and will take a 2-3 hours labour plus parts. I just wondered if anyone has had any success bunging/blocking the feed from within the CWST in order that I can change the gate valve and only have to deal with the small amount of water in the run of pipe between the tank and the valve, there is unfortunately no other service valves before the fault Gate valve.
Thanks In Advance
Kev
