dimmer switch basics
eastend
by eastend » Mon Aug 18, 2008 12:43 pm
I'm runing a cable from an existing wall socket, up behind the drywall to the ceiling and across to a ceiling rose. I've now had the idea of adding a dimmer switch in-line.
What is the proper way to wire the switch? I believe I only need to interrupt the live wire and place the swithc in-line. Is it alright to leave the earth and neutral lines intact?
by ericmark » Tue Aug 19, 2008 7:26 am
Yes you can leave earth and neutral lines intact.
You say running from existing wall socket. If you are referring to 13 amp socket you will need a fused connection unit before using to feed a lamp as the normal light fitting is only rated at 5 to 6 amp and 13 amp socket supply is in the main 32 amp.
By using grid switches you can include a dimmer and fuse in the same unit.
Eric
eastend
by eastend » Tue Aug 19, 2008 11:19 am
Thanks for the quick response. I'm actually drawing off a 5amp lighting socket, so I should be ok, no?
One quick follow-up...if I'm running the line along a finished concrete ceiling (unpainted), would you recommend self-adhesive trunking or conduit (or nothing at all)? Also, must I use a ceiling rose to remain compliant (the lamp includes a plastic connector)?
It is currently Sat Jan 18, 2025 11:06 am
