Pavers over Concrete - New Type of Question
Haus
by Haus » Mon May 07, 2007 1:51 am
Yes, I reviewed the responses on Pavers over concrete but have a slightly differenct question.
The slope on my patio (back left to right front as you look at it) is more than necessary for drainage - it looks a bit awkward.. I want to pave over the concrete with pavers but as I move from back left to front right I am thinking of decreasing the slope with increasing amounts of Paver sand underneath. The left side "soldier course" will be glued to the patio with approved concrete/ paver adhesive and the front and right side will be held in with heavy Unilock wall blocks, not simple edging restraints..
Do you think this approach -increasing amounts of sand underneath the pavers to decrease the slope of the patio will work? I will be starting from the back left with many rows just siting on the concrete and then adding sand. I intend to keep a slope that will be more than adequate for water drainage..
thedoctor
by thedoctor » Sat May 12, 2007 9:33 am
The maximinum a sand base should be is about 75mm so it will work up to that point. The sand then becomes less stable even when compacted and the surface can be afffected.
It is currently Fri Jan 31, 2025 2:00 am
