extending light switch wiring
geezer01
by geezer01 » Tue Aug 19, 2008 4:51 pm
hi guys, i have a little problem
i want to change the location of a light switch....the problem is there is not enough slack in one of the wires.
The switch is a 2 gangway 2 way switch for for the upstairs/downstairs hallway. I think its the 2 way wire which is not long enough...its got a grey, brown and blue wires inside the sleeving.
is there any way of extending the wire...i was thinking a juction box..if so should i use a 20 amp junction box or a 30 amp box?
cheers in advance!
by ericmark » Tue Aug 19, 2008 6:26 pm
Ashley part of Hager do a Maintenance Free Junction Box which you can plaster over but normal one with screws have to be accessible. For lights 5 amp is ample.
Advert shows it as 4 way with 4 connections. The other way is crimp or solder with self alginateing tape then standard insulation tape.
I would visit a whole sale outlet and ask new things every week and they are normally helpfull.
Eric
TOPSPARK
by TOPSPARK » Wed Aug 20, 2008 10:04 pm
If the cable is being extended and you can put the existing cable under the floor then get a 4terminal 20 amp junction box and connect the wire into this and put the junction boxin the floor if this is upstairs.
all the best
Topspark
It is currently Fri Jan 10, 2025 9:50 am
