Glowworm boilder - SwiftFlow - Thermocouple broke?
trickyneath
by trickyneath » Tue Aug 19, 2008 8:09 pm
Hi all,
When I run hot water the pilot light appears to blow itself out after about 10-15seconds. Is this likely to be a thermocouple problem? If so, what course of action do you guys reccommend?
Cheers,
Rich
by htg engineer » Wed Aug 20, 2008 8:00 pm
No, if the flame holds the thermocouple will probably be ok.
More likely to be a dirty pilot, if not a good solid flame - the flame will lift off when the boiler heats up and the fan is running - clean pilot injector and supply pipe.
htg
It is currently Sat Nov 23, 2024 3:10 am
