Air in pumped central heating
Faff
by Faff » Wed Aug 20, 2008 12:00 pm
I have a pumped central heating system that continually draws air in through the vent pipe. (the pipe that drops down into the top of the header tank)
I was thinking a good solution is to extend this pipe so it sits below the water level in the header tank.
Is this a good idea, or not?
parkyplumber
by parkyplumber » Wed Aug 20, 2008 7:45 pm
this is a bad idea as you are effectivley sealing your heating system from the atmosphere. Its called an open vent for a reason.
The pump may be sited in a bad position related to your cold feed or vent pipe
by htg engineer » Thu Aug 21, 2008 5:51 pm
No, you could try extending the vent, it should go to 18" above the tank.
Is this a new problem ? or has it always been the case ?
Pump speed and position may be to blame.
htg
Faff
by Faff » Sat Aug 30, 2008 8:47 pm
Thanks guys, I will definitely give that idea a miss.
The problem has been there since I moved in about 2 years ago.
I'll check the height of the vent and reduce the pump speed. If that doesn't work I'll get someone in to take a look.
It is currently Tue Nov 26, 2024 4:59 am
