Wiring lamps
treehouse
Wiring lamps
by treehouse » Thu Aug 21, 2008 9:22 pm
We have bought some wall lights from Ikea that go with a mirror, expecting a plug on the end of a cable to power them. However, when the box was opened, it needed a cable from a lighting circuit in the wall to be attached to the lights (which we don't have).
Is there any reason I can't attach a normal appliance plug and cable instead?
If so what do I do with the earth wire on the cable as there is nowhere to connect it on the (plastic) light fitting?
KD
by ericmark » Fri Aug 22, 2008 8:01 pm
If the fitting has a double square one inside the other it is Class II and does not require an earth fitting a plug would require a max 5 amp fuse more likely 1 or 3 amp. Not sure of if they can sell without a plug not sure where the line between installed lights and free standing lights falls.
Eric
It is currently Sat Jan 18, 2025 10:55 am
