Mira 723 Shower problem
BAZ2571
by BAZ2571 » Fri Aug 22, 2008 7:49 am
I have a Mira 723 that has suddenly started to "leak" from the shower head as the valve is clearly not shutting off the supply fully. The contor knob is fully closed but still water comes through. Will a new service seal set fix it or is there a more fundamental problem?
TheDoctor4
by TheDoctor4 » Fri Aug 22, 2008 10:19 am
Checkout the DIY project on Leaking Shower or Bath. This may be of some use to you: https://www.diydoctor.org.uk/projects/le ... r_bath.htm
Regards
It is currently Fri Jan 10, 2025 8:50 pm
