running cables!!
KT
running cables!!
by KT » Fri Aug 22, 2008 12:41 pm
Hello,
I am fitting a whole new aerial system throughout the house and need to thread the coax cables to the first and ground floor.
I would like to hear your advice on the different ways in which i can do this.
Although i would like to avoid going outside with the cables!!
Karl
by ericmark » Fri Aug 22, 2008 7:50 pm
You may find http://www.ericmark.talktalk.net/Adding ... ckets.html helpful I would like any feed back. As to getting cables from A to B no real easy way but do remember twin coax is available and if you have got existing holes unlike mains cables where the benzene in washing up liquid can explode if cables go faulty and you need to use yellow 77 lub you can use washing up liquid with coax.
Eric
It is currently Sat Jan 18, 2025 11:01 am
