Salus RT000 RS
skybluekev
Salus RT000 RS
by skybluekev » Fri Aug 22, 2008 3:03 pm
Hi, I'm lloking at buying a thermostat for my central heating system, i was looking at the 'Salus RT000 RS' because i need a wireless one that has volt free contacts. However i have a few questions before i buy this:
1) As the the receiver is mains powered, i intend on putting a plug on it instead of hard wiring it in, what wire would i use and what current rating fuse?
2) I currently have a Ferolli boiler, would i need to buy a specific thermostat for this boiler or ar all thermostats universal?
3) What type wire would i use to connect between the receiver and the terminal on the boiler?
Thanks a lot in advance,
Kev
TheDoctor4
by TheDoctor4 » Fri Aug 22, 2008 6:24 pm
Have you had a look at the DIY project Central Heating - Thermostats: https://www.diydoctor.org.uk/projects/thermostats.htm This may give you some useful information or you may want to contact Heatmiser for further assistance
Regards
skybluekev
by skybluekev » Fri Aug 22, 2008 9:49 pm
Yes i've already checked that, didn't help too much with what i wanted to know.
