Gas hob ventilation. Existing instalation
6 posts   •   Page 1 of 1
slaterlp
by slaterlp » Sun Aug 24, 2008 2:18 pm
Anybody help with this question please.
I have an existing gas hob installed in my kitchen. its a Bosch NET 675.
Can someone tell me if opening a window is sufficient to satisfy the regulations. The house is a 1950s build and the kitchen is double glazed with an opening lovre window (if that is the correct term for a horizontal opening window.)
The kitchen has a door that leads to the back garden.
There is an extract fan above the Hob, that has to be switched on manually.
I am confused by the regulations.
1) Do I need an eair brick?
2) Does the Extract fan have to be automatic?
There is also a Worcester Combination central heating boiler installed on the wall, and this has a room sealed flu.
Thanks in advance. :)
by htg engineer » Sun Aug 24, 2008 8:16 pm
Kitchen with an openable window or door ?
10m2>
No ventilation required
5m2<
100cm2 required
htg
slaterlp
by slaterlp » Mon Aug 25, 2008 9:14 am
Hi htg.
Thanks very much for the reply. My kitchen is just 10 sqmeters. .
Can you tell me where I could find the text that gives these measurements? Is there a web page with these rules I could look at. I was trying to find one, but I just confused :)
I have never had any problem with fumes or the like, so I assume it is safe not to have an air brick. I dont have any objection to one, its just that I dont have a wall that one could go in. The only place would be behind the base units. In fact there is an old one there but it is behind the washing machine.
I am going to have a boiler service and I have been told that if the gorgi engineer thinks that i should have an air brik, he has to turn off my gas until one is fitted.
So I just want to be able to say that the regulations says its ok for a kitchen of my size.
by htg engineer » Mon Aug 25, 2008 4:19 pm
Not if he thinks you should have one - if the regulations state you should. As the boiler is room sealed and the kitchen is 10m2 you don't need ventilation.
htg
by htg engineer » Mon Aug 25, 2008 6:02 pm
slaterlp
by slaterlp » Mon Aug 25, 2008 11:04 pm
Thanks very much for your help HTG, much appreciated and helpful
It is currently Sun Dec 29, 2024 2:25 am
