Hot Water stopped working after fitting new Radiators!!
edwardsm888
by edwardsm888 » Sun Aug 24, 2008 3:57 pm
Help!! I've just fitted two new radiators and had to drain the central heating system down to be able to do this. Now they are fitted and I have set the heating system back to how it was when I started (opened the gate valve and re-set the actuator to Auto) the hot water is not working.
The Boiler fires up for a minute then stops (and requires a reset) so I'm assuming it's not getting enough water to heat up? Any suggestions as to what I might do to fix this will be apprechiated :D
plumbbob
by plumbbob » Mon Aug 25, 2008 6:28 pm
You have an airlock in the system between tank and boiler. You need to remove this.
It is currently Sat Jan 25, 2025 3:49 pm
