REPLACEING A FAULTY GATE VALVE
reg9482
by reg9482 » Tue Aug 26, 2008 3:06 am
HI,I NEED TO REPLACE A FAULTY GATE VALVE AND WOULD LIKE TO KNOW IF I CAN JUST REPLACE THE MAIN BODY AND CONNECT IT TO THE EXISTING NUTS AND OLIVES. IF THIS IS NOT RECOMMENDED HOW DO I REMOVE THE OLD OLIVES FROM THE PIPES,MANY THANKS REG9482
TheDoctor4
by TheDoctor4 » Tue Aug 26, 2008 9:16 am
Have you had a look at the DIY Projects: https://www.diydoctor.org.uk/projects.htm You may find some useful information here.
by htg engineer » Tue Aug 26, 2008 4:47 pm
The nuts and olives will normally fit, if not the olives sometimes come off if you get hold with a pair of grips, twist and pull - alternatively cut them off with a junior hacksaw.
If using old olives with a new valve - it's normally best to put a few wraps of PTFE around the olive.
htg
reg9482
by reg9482 » Wed Aug 27, 2008 4:40 am
thanks to both of the guys who replied to my query your help was much apreciated,cheers.
It is currently Sun Jan 26, 2025 7:16 pm
