electric cooker wiring
kevconnell46
by kevconnell46 » Wed Aug 27, 2008 5:20 pm
we're in the middle of a new kitchen build and also changing our old gas cooker to all electric and re-siting it, l wanted to run a spur from the original cooker switch but the wires from the spur and the original cable are too big to fit in the terminals, is it plausable and safe to join the wires with 30amp connectors and run it straight to the cooker, meaning while other people can turn off their cooker at the switch l would have to go to the fuse box.thanks
TheDoctor4
by TheDoctor4 » Wed Aug 27, 2008 11:17 pm
Have you had a look at the DIY Projects section yet? There are several projects relating to electics and adding spurs. You can view the projects area on the following URL: https://www.diydoctor.org.uk/projects.htm
Regards
by ericmark » Thu Aug 28, 2008 2:27 am
Spur and cooker don't seem to go together? Fused spur unit normally rated at 13 amp and cooker supply 30 amps plus.
Also there are permitted routes for cables.
And being Kitchen will come under Part P.
If your trying to fit 10mm cooker cable into a spur no wonder it will not fit maybe you can read project section and then ask again when you have more idea what you are asking.
It is currently Sat Jan 18, 2025 10:02 am
