Hi, guys.
I have just replaced a Drayton motorised valve which had leaked into the actuator, causing the CH to come on whenever the hot water was on.
I drained the system, as detailed on here, changed the valve, refilled the system - no leaks on the new valve - and the CH is not coming on with the hot water any more
However, when the CH is turned on the radiators are not getting warm and the boiler is turning itself off after about ten minutes.
Any ideas?
