Removal of radiator
6 posts   •   Page 1 of 1
Newps
Removal of radiator
by Newps » Mon Sep 01, 2008 10:42 am
I need to remove the bathroom radiator as i am removing old tiles etc.
Is it best to drain down the whole system or just to close valves on the radiator and remove?
Also when i reinstall the radiator do i need to install new seals or olives?
The central heating was installed lasy year.
Many thanks
Newps
by htg engineer » Mon Sep 01, 2008 9:27 pm
Just close the valves and remove - no need to drain system unless you're changin valves or altering pipework.
htg
Newps
by Newps » Tue Sep 02, 2008 9:54 am
Thanks htg engineer,
Will i need new olives or selas etc when i put the rad back?
Dadwood
by Dadwood » Tue Sep 02, 2008 5:34 pm
Yes, I fully agree with htg engineer. Once you have closed the valves, you will of course have to crack open the connections on the rad side of the valves in order to drain out the water in the rad before removing it. You will need to open the vent cock on the top of the rad to enable the water to drain out fully.
Steve the gas
by Steve the gas » Wed Sep 03, 2008 6:15 am
No you should not need new olives etc
chris_on_tour2002
by chris_on_tour2002 » Thu Sep 04, 2008 10:34 am
new olives will not be required - in fact you'd struggle to get the existing ones off the pipes anyway.
just one thing to note - if it's a towel rail that connects vertically to the pipes and there are no isolator valves fitted then you will need to at least partially drain the system. if a normal rad with side entry valves then no need to drain - just shut off the valves.
It is currently Mon Nov 25, 2024 7:08 pm
