Shower Problem
Blomac
Shower Problem
by Blomac » Tue Sep 02, 2008 5:12 pm
[b]SHOWER PROBLEM[/b]
Have just replaced a old shower (working well but tired)) worked by hot water from the system and cold water from a header tank in the loft. New shower unit is a manual type with a hot and cold feed. The mixer receives the water and flows it up through pipe to further piece at right angle to 6 inch drench type shower head. Before fitting mixer I had good flows from both hot and cold supply. After fitting found that the cold water barely flowed and the hot just a little better. Have checked hot and cold for airlocks using bathroom taps and they seem ok or is the airlocks in the shower pipes? This is the second unit I've fitted the first one did the same. Can anyone advise..........
bobplum
by bobplum » Wed Sep 03, 2008 10:46 am
morning
sounds like not enough pressure to go up the pipe and drench
might need a pump
bob
AdamsHeating
by AdamsHeating » Wed Sep 03, 2008 10:52 am
Some of these mixer showers have a minimum pressure that they will work at. Some are for high pressure some are for low pressure and some do both.
With you having a header tank in the loft you will need a low pressure compatible shower, check what the shower is designed for in the instructions as this incompatibility could be your problem?
chris_on_tour2002
by chris_on_tour2002 » Thu Sep 04, 2008 10:31 am
almost certainly this is a pressure issue. you have probably bought a high pressure shower designed for use with a pump or minimum head. check the installation instructions that came with the shower it will detail the minimum system requirements.
if it is a pressure problem all is not lost - you can fit a pump which will hopefully be the most expedient solution.
It is currently Fri Jan 10, 2025 7:53 pm
