no cold water in shower
tegs
by tegs » Tue Sep 02, 2008 8:52 pm
Hi All
First time on the forum
I have just fitted a new hansgrohe thermostat concealed shower unit to a gravity system using existing pipework thoughly flushed both hot and cold sides through the Ibox then fitted the thermostat unit but when i try to turn the the temperature to the cold it just shuts the cold water supply. So no blockage cold getting to the Ibox do you think the non return vale within the thermostat unit could be faulty bearing in mind this is a brand new shower unit. the hot is on the left and the cold is on the right of the thermostat unit as the instructions.
Any advice would be most welcome.
Tegs
bobplum
by bobplum » Wed Sep 03, 2008 10:43 am
morning
cold / hot is this from the back view or front view could be the pipes are in the wrong place
bob
It is currently Fri Jan 10, 2025 8:24 pm
