How to attach a bath panel without drilling?
jamesburdett
by jamesburdett » Mon May 07, 2007 7:23 pm
how do i atatch a solid mdf bath panel without drilling it and only able to lift it verticaly to take it off
jim
Arnak
Fitting a bath panel.
by Arnak » Sun May 13, 2007 10:52 am
Well the only way I can think of is to fit a frame around the bath so that it fits under the lip of the bath.
Leave just enough room for the panel to fit between the frame and the bath at the top then at the bottom rebate the panel and fit some strip magnets.
They can be brought in a length as a roll and cut to size.
Rebate the bottom of the frame to take the opposite strips of magnet.
With the panel cut to just enough height to fit under the bath lip but only high enough to allow you to lift the panel vertically so you can slot it in at an angle then drop it down to slid onto the bottom magnets.
The top should be held firmly as it is trapped between the bath and the frame, the bottom is held tight by the magnets.
Don't have the top fit too tight or you might scratch the panel getting it on and off.
Hope that helps,
Arnak
It is currently Mon Dec 02, 2024 3:40 pm
