Instructions for fitting a UPVC bowed window
Mollyrockers
by Mollyrockers » Wed Sep 03, 2008 8:21 pm
What are the main point for fitting a UPVC window
TheDoctor4
by TheDoctor4 » Thu Sep 04, 2008 11:06 am
Have you had a look at the DIY Projects section: https://www.diydoctor.org.uk/projects.htm There are several projects related to all aspects of UPVC windows that may be of some use to you.
allan the locksmith
by allan the locksmith » Fri Sep 05, 2008 9:03 am
If Its a bowed window make sure you support the ceiling with an acro prop.
fitting bow window
by welsh brickie » Fri Sep 05, 2008 8:46 pm
the main problem with fitting is the cill.
you just have to be carefull when cutting the cill so cut a bit off at a time and keep checking.
you will use mdf for the internal cill counter levered so be carefull cutting that.
Use gallow brackets for under the cill this will stabilise the weight.I dont know if your using grp roof or deciding to cut lead but in any case if you dont have experience of doing this type of job I think you will have trouble
fitting it,I suggest employing somebody to do it for you.
It is currently Fri Nov 22, 2024 4:22 pm
