Block Paving
lawsonsd
Block Paving
by lawsonsd » Thu Sep 04, 2008 9:42 am
I've resently moved house and inherited a block paved path around my new house. There are a lot of weeds coming up between the setts and I wondered what was the best way of removing these and ensuring that they don't return.
I have a power washer but have heard that this could damage the setts. I also have a kneeling pad and scraping tool, but as there is a lot of path, I was hoping there might be an easier way of addressing this problem.
If you could suggest a good way of addressing this issue I'd be most grateful.
Regards
Stephen
wabbitpoo
by wabbitpoo » Tue Sep 09, 2008 3:38 pm
The only "damage" the pressure washer would do is to blow the sand out from between the blocks, which you can re-apply. Use kiln dried sand, on a dry day and on a dry drive.
Alternatively use a weed-killer.
It is currently Sat Nov 23, 2024 1:35 am
