Cooker switch neon light
mikescho
by mikescho » Sat Sep 06, 2008 6:49 pm
I have just replaced my cooker switchwith a new 20A D.P.Switch and wired it up the same as the old one as far as I can see. However, the neon light stays on when the switch is off. Is this a feature of new ones or if not can you suggest what the problem might be?
Thank you.
by ericmark » Sat Sep 06, 2008 7:29 pm
If in and out are swapped it would cause the neon to stay on.
20 Amp seems a little low for a cooker are you sure it is for a cooker?
Eric
It is currently Sat Jan 18, 2025 1:15 pm
