fireplace
GEOJUL123
fireplace
by GEOJUL123 » Tue Sep 09, 2008 9:01 am
I am in process of fitting new fire surround and gas fire, the stone back panel that fits to chimney breast along with surround has opening pre-cut
for the new fire, the actual opening in chimney breast is however larger than the opening in the stone back panel. Should I brick up the opening in the breast to same size as opening in stone back panel or is it O.K. to fit new panel and seal as is.??
[list][/list]
TheDoctor4
by TheDoctor4 » Tue Sep 09, 2008 10:37 am
Have you had a look at the DIY Projects area of this site: https://www.diydoctor.org.uk/projects.htm There are several projects related to fireplaces that may of some use to you.
Regards
It is currently Thu Nov 21, 2024 7:22 pm
