skirting
matanhale
skirting
by matanhale » Tue Sep 09, 2008 5:40 pm
Had our living room re-plastered and going to fit laminate floor for the floor covering. We had to have a chemical injection damp proof, so the new plaster starts at approx 4" above the floorboards on the walls with the damp proofing.
I removed the old skirting (and wedges) and will be replacing with 5½" skirting. My question is will I need to replace the wedges so that the skirting has something to rest against?
goghat
by goghat » Fri Sep 12, 2008 10:49 pm
u will need to pack behind the skirting in order to stop it folding in . so i would knock in some wedges and then cut them off flush with plaster to stop the skirting folding in.
TheDeeJoiner911
Your Skirting.
by TheDeeJoiner911 » Wed Sep 17, 2008 9:35 pm
You could also pack out the skirting using a batton of timber along the bottom- being the thickness of the plaster off the wall it will keep the skirting plumb. Then plug and screw it and fill the holes. Works for me every week.
matanhale
by matanhale » Mon Sep 22, 2008 1:06 pm
Thanks for the replies - I was thinking I would have to replace the wedges (which would be a bit of a pain), or use some battens along the bottom of the skirting. I may have to plane the battens, but probably easier than relacing the wedges??
chris_on_tour2002
by chris_on_tour2002 » Fri Sep 26, 2008 10:20 pm
or some really good, generous dollops of grip fill, regularly spaced. adjust the skirting to the required position, once hardened it will stay there. a few screws for good measure...
It is currently Wed Nov 27, 2024 2:04 am
