I am currently renovating a cottage, and would like to switch some table lamps on and off from a wall socket. I've seen in older houses these 5A round pin plug and socket for lighting circuits and they are availiable in screw-fix.
What i would like to know is, are thay exceptable in new elecrical installations and how are they wired. i.e With a celing rose the the live is "switched" in the rose, i assume that the socket only has the earth, Live and neutral connections so will they have to be switched in a 4 way junction box?
