Redring "Expressions" shower
kgilhespy
by kgilhespy » Tue Sep 09, 2008 10:10 pm
Expressions 5000 elec shower problem.
"Overheat light" switch comes on even when only set to "medium" so never gets warm. Has worked OK for over 2 years.
Makes no difference adjusting the flow.
Is it fixable or does it need replacing completely?
by htg engineer » Wed Sep 10, 2008 7:25 am
Check and clean filters, if the water flow is reduced the heat may not be getting away from the unit quick enough.
htg
It is currently Thu Dec 12, 2024 4:48 am
