by Paul Pepper »
Sun May 13, 2007 3:37 pm
Not down to any regs other than those regarding pressure loss. The further the boiler from the gas meter, the larger the interconnecting pipework needs to be in order to cope with the pressure loss. The majority of boiler manufacturers do require a 22mm supply, but not all. Had you considered running the gas supply up the outside wall, into the loft space and then down to the boiler? Would eliminate the need to destroy new floors!
Paul
