Electrical: cord switch
Martyn Petes
by Martyn Petes » Fri Sep 12, 2008 11:23 am
Fitting a new pull cord switch, (bathroom light) replacing old one. But for some reason new one is blowing the fuse?? and yet wiring is right.
BLAKEY1963
Re: Electrical: cord switch
by BLAKEY1963 » Fri Sep 12, 2008 7:15 pm
[quote="Martyn Petes"]Fitting a new pull cord switch, (bathroom light) replacing old one. But for some reason new one is blowing the fuse?? and yet wiring is right.[/quote]
MARTYN PETES
your wiring as u say is right and yet u r blowing fuses.
I have accidently seen the earth wire put into one of the
3 terminals on the switch .( on two way pullcords ).
I am not sure what connections u have made with
limited infomation given.
To conclude as u state your wiring is right ,
u could have a fault elsewhere , so i would
advise u to get someone in.
BLAKEY1963
Martyn Petes
by Martyn Petes » Fri Sep 12, 2008 7:43 pm
Thanks for the reply. The earth is correctly wired, simple cord switch (or so I thought) only 2 terminals with the earth wired to the unit itself. It is basically like for like with the old switch...but still tripping. Can only think it is the switch itself that is faulty. all wires insulated and in good order. Got me beat. But thanks again for responce.
by sparx » Sat Sep 13, 2008 10:34 pm
Hi, did you change whole switch including patress ? if so have you knicked live to earth with fixing screw? undo patress and try light again
Martyn Petes
Electrical: Coerd Switch
by Martyn Petes » Sun Sep 14, 2008 9:23 am
Thanks Sparx, Patress changed and yes it was the screw fixing into the earth. Sometimes the most simple of things lol. Thanks again for your help.
Martyn
It is currently Sat Jan 18, 2025 11:08 pm
