DAMP IN MIDDLE OF HOUSE
marianne1976
by marianne1976 » Fri Sep 12, 2008 9:40 pm
i have a wet patch on an internal wall in the centre of the house it is both sides of the wall ie on the living room and hallway less then a foot in dia. the paint is wet flaky and smells fusty . i do know the external pointing needs doing and have heard suggestions that the external walls may be so wt this is causing an internal problem ..... any suggestions
GoNz0
by GoNz0 » Sun Sep 14, 2008 10:59 pm
i have the same, its rising damp due ot the internal walls not having a blue brick course for some daft reason.
stuart C
damp in middle of house
by stuart C » Sun Sep 14, 2008 11:06 pm
It could be a leaking pipe. This is the most common cause of dampness on internal walls.
stuart138
by stuart138 » Tue Sep 16, 2008 9:13 pm
Do you have solid Floors?
Problems can occur on internal walls , if the floor has been filled in .
The reason being is many companies who do under pinning and concrete floors do not allow for the damp proof course , and once filled in are above this .
It is currently Sat Nov 23, 2024 5:08 pm
