Shower valve - Pressure
cerdyn
by cerdyn » Sun Sep 14, 2008 1:43 pm
I want to purchase a shower thermostatic valve to operate with my combi. Many of the valves I am looking at are low pressure but say they work with high pressure, another has to have minimum of 2 bar. I understand that idealy the valve should opperate at times of day when pressure may drop. can anyone advise before I buy whether either these option will opereate efficiently.
Many thanks
plumbbob
by plumbbob » Sun Sep 14, 2008 9:23 pm
As long as the mixers are designed to work on high pressure, and you have a high pressure system such as a combi, then all should be fine regardless of the time of day it will be used.
The problems only start if a high pressure shower is used on a gravity low pressure system, as it would not work. There would also be a problem with a low pressure only valve being used in conjunction with a combi.
It is currently Tue Nov 26, 2024 8:42 pm
