Internal leaks in Polycarbonate roof
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
GrahamT
by GrahamT » Mon Sep 15, 2008 9:07 am
We have a conservatory (now three years old) with an opaque polycarbonate roof consisting of multiple channels. About 12 months ago we noticed a bright green discoloration at the lower end of most of the panels. Closer inspection revealed that this was within the channels of the roof, not inside the conservatory or outside it. The builders were reluctant to help, stating that. in their opinion we were not ventilating the conservatory correctly, and that it was our 'lifestyle' that was causing the problem, and that there was noting wrong with their workmanship. All of this without a site visit to view the problem!
Eventually, they sent their 'senior installer', who agreed with us that the sealing strips at the end of the channels had started to leak, allowing water to leak in. Closer inspection allowed us to see pools of water forming leading to algal growth (the cause of the green colour.)
After some "debate", it was agreed that they would remove, clean and reseal the roof panels, which was done.
The problem has now returned, and a 'phone call this morning has been met with the same response - 'it's not our fault, the humidity in the conservatory is too high allowing moist air to permeate through the polycarbonate leading to condensation etc'
I have no intention (or the skills!) to attempt a DIY repair.
My question is - where can I go from here?
roof panels
by welsh brickie » Tue Sep 16, 2008 8:55 am
unfortunatly the only way to clear that mould is to replace the panels,they could take the panels out clean them all day long but if there is any moisture at all left in it will cause green alge to form.
Your lifestyle has nothing to do with the problem its a faulty panel or the breather tape hasent been fitted to the bottom of the polycarb.
Also check if the gutters clean this can also cause problems.
The panels should last more than 3 years they should replace them really but good luck with that.
It is currently Sun Jan 05, 2025 5:09 am
