Paint or Wallpaper ?
jaffacake2000
by jaffacake2000 » Mon Sep 15, 2008 1:23 pm
I want to re-do my flat, the wallpaper is quite old but i want to know if i should use paint or use wallpaper?
Some people say that wallpaper keeps the room warm and if you paint the room in the winter the room will feel even colder even with the heating on. Is this true?
I live in a flat on the top floor and while we have wallpaper now, in the winter its cold and even the heating doesnt help much. We have double glazing and insulation.
plumbbob
by plumbbob » Mon Sep 15, 2008 8:38 pm
I am not sure that wallpaper offers any increase in insulation. Maybe the wall may initially feel warmer when touched, but the thickness of barrier is insignificant when it comes to heat loss.
Frankly, it is the fashion these days simply to paint the whole room a neutral shade with white ceilings. This goes for all properties - rental or not. Really what is going to be the decider between paint and wallpaper is the quality of the plasterwork. This is why so many rental properties use woodchip (yuk) paper. It's easy for a quick overpaint between lets. Spalsh and dash as it's known.
chris_on_tour2002
by chris_on_tour2002 » Fri Sep 26, 2008 11:36 pm
if your flat is that cold that you think wallpaper is going to make a difference then you want to be looking elsewhere for a solution to your winter shivers! loft and cavity wall insulation (tricky in a flat admittedly) double glazing, draught proofing, a more energy efficient heating system and woolly jumpers will keep you warm, not wallpaper!
the thermal insulation properties of a sheet of paper less than 1mm thick are so negligible as to be imperceptible. as to whether or not you paint or paper, that's a question of taste and style. don't base your decision on the warmth factor. you'll gain very little in that respect through papering.
as plumbbob says it might make the walls warmer to the touch but that's about it. and as you have acknowledged yourself, it's still cold with your existing wallpaper.
lining the walls with thin sheets of polystyrene prior to papering used to be popular and was said to aid insulation but it's not so common these days, largely down to the fact that it's effectiveness is hotly disputed.
It is currently Sat Nov 23, 2024 10:41 am
