Loc laminate, carpet and laminate underlay
dontmindifido
by dontmindifido » Mon Sep 15, 2008 8:58 pm
I have just laid my loc laminate on the existing carpet underlay (which is in very good condition) and new fibreboard laminate underlay. Obviously there is some movement in the boards, is this a problem? Are the boards designed to flex in this way?
mr_vampy
Re: Loc laminate, carpet and laminate underlay
by mr_vampy » Tue Sep 16, 2008 11:00 pm
[quote="dontmindifido"]I have just laid my loc laminate on the existing carpet underlay (which is in very good condition) and new fibreboard laminate underlay. Obviously there is some movement in the boards, is this a problem? Are the boards designed to flex in this way?[/quote]
Using carpet underlay would give you too much bounce on the laminate flooring. It is recommended you remove the carpet underlay and just use the fibreboard underlay. By the way, what type of subfloor do you have? If it's concrete, then you should also use a DPM. Hope it helps
It is currently Fri Nov 15, 2024 9:33 pm
