conventional television brackets on a plasterboard wall
Lamby
by Lamby » Tue May 08, 2007 4:05 pm
Hi. After consulting the website, i have decided that the redidrive fixing seems to be the one to use to fix a television/dvd wall bracket to a plasterboard wall.
However, before ordering some of these fixings, I want to check whether these will reliably hold up the bracket with an old heavy television and a dvd player on it! The television weighs about 12kg, and the dvd player 3kg, and the bracket itself is quite substantial too. I'm just a bit worried that what seem like small fixings won't be able to hold all that weight, so any advice is very welcome!
Thanks in advance!
thedoctor
by thedoctor » Sat May 12, 2007 10:15 am
We obviously can't give you any guarentees but if you have doubts then fix a suitable piece of timber across 2 or 3 upright timber studs in your wall and fix the brackets to that. The timber can be decorated to either match the wall or be a complete contrast to form part of the set up.
Arnak
Fitting a support.
by Arnak » Sat May 12, 2007 1:07 pm
If you do not want to see the timber support then cut back the plaster board and half lap the timber into cut outs in the studs.
Then cut and fit a new piece of plasterboard into the slot and re-plaster
Arnak
It is currently Sun Dec 22, 2024 10:22 am
