What size rawlplugs to be used?
CeceBauer
by CeceBauer » Sat Sep 20, 2008 2:55 pm
Hi. I'm trying to fix a mirror which weighs 17kg to a plasterboard wall. I have 7mm plastic rawlplugs but not convinced they will hold the weight. Any advice would be most welcomed!
Steve the gas
by Steve the gas » Sun Sep 21, 2008 6:52 am
What's behind p/b?
If it's brick or block-- fix to that with looong plugs and screws.
If not - try a batton fixed to p/b a few times then fix to that.
Hth
plumbbob
by plumbbob » Sun Sep 21, 2008 1:48 pm
You can't fix that weight to plasterboard walls alone with a simple rawlplug. As Steve says, what is behind the plasterboard? If it is a hollow wall, you need a trip to your DIY store to buy some proper cavity wall fixings. If behind the plaster is a solid wall, you could still use the plugs but use 2.5" or 3" screws and make sure the plugs are trough the plaster into the wall itself.
It is currently Sun Dec 22, 2024 7:10 pm
