by thedoctor »
Mon Jul 04, 2016 7:06 pm
The powder you can see on teh surface is called Efflorescence as stated in the post below. You can find out more about it here. If you have a look at the DIY Doctor project relating to efflorescence, it may provide you with a little more information:
https://www.diydoctor.org.uk/projects/efflorescence.htmEssentially all stone/masonry etc is made up of minerals and salts from the earth. It also has both a moisture content. Some of the salts are water soluable and, while the water is in the stone (more after heavy rain etc) the salts dissolve. When it stops raining, the water in the material tries to escape to the surface where it evapourates. As it travels to the surface it brings the soluable salts with it. It evapourates on teh surface of the wall or patio and leaves the salts behind. This is what you can see.
On a very dry day, you can brush these salts off. Sometimes it takes a good brushing with a "SOFT" wire brush "CAREFULLY" to remove them. Then, to avoid the situation occurring again, it is a good idea to seal the surface of the stone/masonry etc.
The best stuff for sealing Indian Sandstone is (believe it or not) Indian Sandstone Sealer !! You can find out more about this by watching the video at this link where you can even buy the stuff.
Be aware that it is NEVER the case that a slab or brick or block etc will be entirely free of water. They absorb it from the air, the ground, spilt drinks etc. Treating with a sealer does not guarantee a salts free surface but it will reduce the efflorescence by at least 85% if applied properly.
Good luck
https://www.diydoctor.org.uk/DIY-superst ... litre.html
