Venting pipe in domestic water system.
grakar
by grakar » Tue Sep 23, 2008 5:09 pm
A pipe rises from the waste water pipe from our bathroom sink and goes through the roof I assume for venting purposes. This pipe encroaches on space I need for a vanity unit and I wonder if it can be removed. As I understand it no smell can come up through the sink as there will be a trap fitted. What please is the function of this pipe and can it be removed?
jim the plumb
by jim the plumb » Tue Sep 30, 2008 8:53 pm
You are probably talking about the 4inch soil pipe that extends through the roof to the open air. This pipe vents smells from the toilet/ waste drains to open air.
You can fit a 'durgo', or 'air admittance valve' by cutting down this 4inch pipe, but the valve must remain higher than the highest waste in the bathroom. i.e. the basin.
HTH, jim
grakar
by grakar » Wed Oct 01, 2008 9:12 am
Thanks Jim for your reply.
The waste water from the basin in addition to venting through the roof is piped to a rainwater down pipe. This pipe is open to the rainwater gutters on the roof. Do I need further venting? The soil pipe from the WC is fed to a separate downpipe.
grakar
It is currently Sat Jan 11, 2025 3:11 am
