wiring a TV aerial with multi inputs
apearson
by apearson » Tue May 08, 2007 9:17 pm
I have just moved into a new house and it has 4 rooms with tv points. Imagine my surprise when I went to install the aerial in the attic to find that all 4 were wired seperately. How should I attach these to the aerial - surely not 4 aerials - is there a means of connecting all four into one then that onto the aerial - also do I just commect the middle wire within the aerial - there doesn't appear to be anywhere to attach the outer wires
thedoctor2
by thedoctor2 » Wed May 09, 2007 8:53 am
You need an ariel spltter box , some are powered and some not , i would use the powered one , check out the Projects Pages on here under ariel's /tv , hope this has been of help to you there
apearson
Many thanks I'll review the notes and give it a try - thanks
by apearson » Wed May 09, 2007 1:42 pm
[quote="thedoctor2"]Hi
You need an ariel spltter box , some are powered and some not , i would use the powered one , check out the Projects Pages on here under ariel's /tv , hope this has been of help to you there[/quote]
It is currently Wed Jan 08, 2025 2:54 pm
