over laying joists in the roof space
new boy
by new boy » Wed Sep 24, 2008 9:47 am
hi i am having my loft space insulated up to 270mm (thickness of insulation) but i am also having it over boarded with chip board flooring my problem is that my original joists are not high enough to accommodate the new insulation they are only 150x50mm.
can i put wood onto the joists to give me the extra height i need and should it be put directly on top or at 90 degs to the original joists
thanks for your time
Perry525
by Perry525 » Tue Sep 30, 2008 6:17 pm
Ignore the fiberglass idea use polyurethane instead, foam sprayed/poured between the joists will provide a much better job, your home will be warmer and you can pile things onto polyfoam, making the loft space useful.
It is currently Sun Dec 22, 2024 4:27 pm
