cistern - toilet siphon leaking
krill
by krill » Tue May 08, 2007 10:41 pm
had a look at the projects but this issue not covered it seems.
needed to replace the siphon due to a split flush diagphram on my close-coupled cistern.
I used one of the siphons pictured below.
did this no worries - but it seems there is a leak since I am getting water dripping off one of the bolts which secures the cistern to the pan.
The bolts secure onto a metal plate of a cistern coupling.
It seems there is no other place the water could be coming from but through the hold where the siphon feeds into the pan.
any thoughts on a solution?
[img]https://www.screwfix.com/sfd/i/cat/95/p2635095_l.jpg[/img]
https://www.ultimatehandyman.co.uk/wc%2 ... %20kit.jpg
thedoctor2
by thedoctor2 » Thu May 10, 2007 7:05 pm
Did you replace the black donut to its a soft circular seal between the cistern and pan
krill
by krill » Tue May 15, 2007 10:09 am
yes I did replace the donut.
In fact it seems to have settled down now - the leak has stopped. Maybe the siphon washer needed time to bed in? It seems to have sealed now anyhow.
thanks.
It is currently Mon Dec 23, 2024 12:42 am
