Preparing concrete base prior to tiling
Graham H
by Graham H » Thu Sep 25, 2008 2:36 pm
I have just laid a 2.3m sq concrete base as level as possible. It is at least 150mm thick and reinforced. I am going to lay ceramic tiles before a hot tub is positioned on it (average weight 1tonne when full). Would a SLC be a good idea to prevent the tiles cracking under the load? If so are there certain types. This project is in Cyprus with a temperature range between 0 C and 40+C in case this is another thing for consideration.
self level compound
by welsh brickie » Thu Sep 25, 2008 4:30 pm
yes it would be ideal to use slc first ,I tend to use the latex compound it sets better.
It is currently Sun Dec 22, 2024 7:44 pm
