TILING ONTO A LAMINATED BATH SIDE
Bellafewshe
by Bellafewshe » Fri Sep 26, 2008 12:56 pm
Can anyone advise me on what preparation is required before tiling onto a laminated bath side and what sort of adhesive and grouting should I use?
Many thanks
chris_on_tour2002
by chris_on_tour2002 » Sat Sep 27, 2008 12:29 am
most tile adhesives can be used to tile on top of existing glazed ceramic tile. if they can stick to a glaze they should also be able to stick to laminate. i'd go for a flexible grout and adhesive. stiffen the panel if necessary with battens at the rear to reduce bowing and movement.
ensure that the surface is spotlessly clean and a rub-down with some fine sandpaper would do no harm.
good luck!
It is currently Wed Jan 08, 2025 6:25 am
