About to fill foundation trenches, but what do i do with dra
Rusty bullet hole
by Rusty bullet hole » Fri Sep 26, 2008 5:54 pm
Hi all,
As it says really, i have dug my footings, 600 wide by 1 metre deep but have existing services (gas, electric & water) all passing through the trench. I'm not sure that i understand the best way to protect/ encapsulate said services prior to pouring concrete. I know people have suggested laying lintels over them, but i dont understand how that works when the services are about 500mm down in the trench?!?
Anyone got any ideas?
Thanks in advance
tanto
by tanto » Sat Sep 27, 2008 9:45 pm
Pour concrete in foundations, build blockwork up to undersides of services or as near as, then build over services using lintols to span from one side to another. Once solum has been filled you can surround the services with sand for extra protection.
sevices in trench
by welsh brickie » Sun Sep 28, 2008 10:07 am
if your concrete covers the gas, electric etc use pipe insulation to protect.
If the service pipes are visible after concrete is poured,start you brickwork and when you meet the pipes bridge over them with a concrete lintol.
It is currently Mon Dec 02, 2024 6:41 pm
