Installing a new Radiator
fraseraze
by fraseraze » Sun Sep 28, 2008 9:52 pm
Hello all.
We have had some building work done in two rooms of our flat. Both radiators were removed (one from each room) and are to be re-positioned on the other wide of the room, under the window.
My question is this: Rather than wait for a plumber, I'm considering pulling up floorbards and running some pipes in myself. Fitting the radiator should be relatively easy however, I'm considering using plastic piping as this seems a much simpler and more versatile way of plumbing.
Is this a safe and effective means of piping for a central heating system? The pipes themselves are easy to fit, even for a novice.
F
Steve the gas
by Steve the gas » Mon Sep 29, 2008 5:40 am
Hi Fraser,
Yes you can use plastic,but,any visible pipe in copper IMO.
Are you sure you are able - you need inserts for the plastic for example?
Hth
It is currently Sun Nov 24, 2024 6:19 am
