cutting a concrete path
pbramley
by pbramley » Mon Sep 29, 2008 10:56 pm
i have a path 6inch deep and wanting to cut through the concrete. i have already cut a line but it only goes 2 inch deep. how do i break all the way through the rest ??? please help.....
misery
by misery » Tue Sep 30, 2008 12:04 am
You could hire a stihl saw which has a 12" blade and would cut easily through the rest ,or hire a kango and break the concrete up to your line and with a bolster blade inserted chip away at the concrete to form your straight edge ,wont be perfect edge but if it needs to be could mix up some mortar to make good.
Hope this helps
Misery.
Steve the gas
by Steve the gas » Tue Sep 30, 2008 4:33 am
You could hire a 12" petrol saw (Stihl saw) that will cut deeper and better, use a diamond blade and correct PPE.
When cut to max depth you can then break the last bit with a breaker or a sledge hammer.
Hth
It is currently Sat Nov 16, 2024 10:00 pm
