consumer unit
jim7911
consumer unit
by jim7911 » Tue Sep 30, 2008 10:19 pm
prior to changing the consumer unit, what authority do I need to pull the main incoming fuse 100A, and is it a case of just breaking the seal and removing the fuse
by ericmark » Wed Oct 01, 2008 1:43 am
Simply you can't.
Either you ask for an isolator
Or you have supply disconnected and then reconnected which is likely to be days rather than hours apart.
Or you provide a new consumer unit and tails and ask them to transfer power.
Because of the rules and regulations they are not permitted to give you permission to draw fuse. I know many electricians do but they are breaking the regulations by doing so. Normally if the house holder then tells the supply authority the seal has been broken they will come and re-seal with out too much hassle but that is up to the discretion of the supply authority and they can start proceedings and or remove supply.
Eric
It is currently Wed Feb 05, 2025 9:53 pm
