kitchen plinth / skirting
lyndad
by lyndad » Wed Oct 01, 2008 8:05 pm
Silly question - looking for some ideas.
we have a very uneven kitchen floor, and currently no plinth around the base of our kitchen cabinets.
all standard plinths / conti board etc. are minimum 15cm depth - the gap between the floor and our cabinets ranges from 13cm to 17cm.
so the question is - is there other materials we could use? or, if i use conti board, could i use a band saw to cut along the horizontal length of the board? or should i use a jigsaw?
seems like there should be an easier solution...
chris_on_tour2002
by chris_on_tour2002 » Tue Oct 07, 2008 6:25 pm
you can use a jigsaw but make sure you use the right blade, ie one that cuts on the DOWNWARD stroke and cut face-up. that way you will minimise the chipping to the conti board. most of the chipping will be on the rear side where it won't be seen.
It is currently Wed Jan 08, 2025 5:08 pm
